Add Custom Columns to Search Results~Pro Intralink Windchill
I'm currently using Pro Intralink 8/Windchill with Wildfire 2.0 and I'm trying to add a column to my search results(using Advanced Search) based upon a custom parameter specified in the ProE part. I know how to use Custom Results Button(Shown as attached image after button was pushed) which allows you to show different columns, however this parameter isn't shown.
For example, there is a custom parameter in all our parts called DESCRIPTION. When I go to Windchill, and do an Advanced Search and use the pull down menu under Criteria, DESCRIPTION is an option which I can add, then I place my search term next to it. The search will return numerous results; however it doesn't show DESCRIPTION as a column and even if I click the button in the upper right of the search results(as shown) to customize the columns shown, it doesn't show DESCRIPTION or any of my other custom parameters as an option to show.
Anyone know how to add custom columns to the search results if they arent shown in under the configuration button?
RE: Add Custom Columns to Search Results~Pro Intralink Windchill
