change gap between dimension line and value
Am trying to change the gap between the dimension line and the value in solidworks 2008. I did not find any setting that will change this gap (marked in attached figure).
has anyone ever tried to modify this setting?
RE: change gap between dimension line and value
I don't know of a setting which changes that gap.
Why do you want/need to?
A workaround if you have to, is to add a space above and below the <DIM> in the Dimension Manager.
cheers
The setting seems pretty standard, so I'm also not sure why you'd want to change it.  If you'd like to add text or an object above or below the text, then you can simply add it to the dim text in the PropertiesManager.
It would be nice to be able to control this gap just to have the ability to do so, so I'm not opposed to having an ER for this.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
