No tapped holes in drw from assy
Houston, we have a problem.
When a drawing is made of a part, the tapped holes are dimensioned as taped holes (ex. M10)
When the same part is inserted in an assembly and then a drawing is made, the tapped hole are dimensioned as simple holes (ex. Ø10)
even in the assembly itself the tapped holes aren't tapped anymore. no way to see the cosmetic thread feature doesn't work.
Very annoying, every time I have to override the dimension value.
Annyone ....
Noxi
SW2008SP4
RE: No tapped holes in drw from assy
Djeezes, that simple. Shame on me.
In my defense: sometimes you can't see the forest trough the trees with search engines.
thanks Chris
Noxi
SW2008SP4
