Mating a point to a curve
Im trying to mate two parts within an assembly, one is a weld torch, the other a part with a complex 3d surface. I have created a composite curve on the surface that represents the weld path. Ive drawn a point on the end of the torch and I am trying to mate this point to the curve.
No luck so far, any tips?
RE: Mating a point to a curve
-handleman, CSWP (The new, easy test)
Dan
www.eltronresearch.com
Dan - I will have to check out the path mate, hadnt seen that yet. Looks like it has a lot of functionality - roll, pitch, etc.
Thanks for the help guys.
Jeff
