can i change scale in an Assembly?
I used scale for parts but i was trying to scale a whole assembly but i can't find features.
Can I use scale in an assembly as well?
RE: can i change scale in an Assembly?
-handleman, CSWP (The new, easy test)
regards
Dan
www.eltronresearch.com
I'm honestly not suggesting you do it, but would it be a major undertaking to create a macro which traversed an assy, created a list of components, distance mates, assy plane offsets, etc., and then used the ModelRescaler macro from http
This question has been asked several times over the last year or so.
I tried to save as part and rescaled around coordinate system and it worked fine with me, at least i can import it as a part now and insert it in my assembly.
