identify steel from composition
Is there a good resource I can use to identify a steel by its chemical composition? I received an MTR from a vendor who wants to substitute a material, but there's no specification on it (unless "58 x 295" is a designation I'm not familiar with?) and it doesn't look like it matches anything in Jorgensen particularly closely. I guess what I'm imagining is some sort of dichotomous tree that breaks everything down by specified ranges, and after I enter the percentages of a few additives it's narrowed down to a list of possibilities.
Of course, I've asked the vendor to give me the designation, but while I wait for a response I'm curious to know if this is possible...
Thanks!
-Mark
Thanks!
-Mark
RE: identify steel from composition
http://www.matweb.com
For true identification, you need to compare with published documents like standards (ASTM, ISO, SAE), the ASM Handbook series, or one of the better guides (Stalhschluessel, ASM's Worldwide Equivalents).
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Joe Tank
Anyway, it turns out the material was (CSA G40.21) 50W - it certainly didn't mention that anywhere on the MTR. Is that common? I've only glanced at a few in the past, but I don't remember noticing that they didn't include the spec being tested to.
