Excel Order of Operations
I was browsing through the threads and came across a warning, and ensuing discussion (thread404-157296), on whether Excel should calculate the expression -5^2 as equal to 25 or -25. If you use the Excel function Power(number,power) then there is no ambiguity. If you want to square -5 then you would enter, =Power(-5,2). If you want to negate the square of 5, then you would enter =-power(5,2).
RE: Excel Order of Operations
-handleman, CSWP (The new, easy test)
Lol. Good point.
And as far as operation order, if you remember your high school math class in the absence of parenthesis the equation should be computed by taking powers/squares first, then multiply/divide, and lastly add/subtract.
ISZ
As hammers go, Excel isn't a good one.
- Steve
It equals 25. -5^2 = (-5)^2 not -1 x (5^2)
No way! It equals -25. -5^2 = -(5)^2 = -1 x (5^2)
Check any algebra book.
The end conclusion in that thread was: use parentheses so you get the answer you expect.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
