Error messages
Error messages
What seems to be a problem?
Right now, I'm making a model of a column for a revamp project using initially ASME code 2007 then changed to ASME code 1995, then, tried ASME code 1995 to ASME Code 2007. In the conversion when I executed the latter I got an error message "GetRows failed. The requested column is not a member of this recordset".
