Copies of assemblies/par files to be used in other assm's
First time poster here, so bear with me.
V19 user.
I have been tasked with creating a "base" assembly which will be used in various other assemblies. All of the individual part files within the "base" assembly will be used in the future assemblies. However, features such as cutouts and hole locations are created with includes and include with offset from a piece part. This piece part will drive any changes to the other "base" components.
I have created the "base" assembly, and through "save as" and "save copy as" have created the first future assembly.
I have set up the new assembly so that when viewed in revision manager, all of the part files listed under the new assembly are "copies" of the origional part files.
Upon opening the new assembly, everything is fine.
However, when I edit the new piece part, which should drive the changes to the other part files, it seems as though the included geometry for the first cutout still refers back to the old part.
I have gone back and changed the geometry to the origional piece part, and this still does not have any effect on the new part files. Help.....
Is there a way to save an assembly so that it's component part files can be edited in other assemblies without those changes appearing in the existing instances of those same part files. I still need for there to be associative links between the new part files that make up the new assembly. But I want them driven by the new piece part.
V19 user.
RE: Copies of assemblies/par files to be used in other assm's
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
thread562-210643: Revision Manager Training Material
Also I believe karmoh had a good thread about using revision manager.
KENAT, probably the least qualified checker you'll ever meet...
I had tried saving copies with the use of revision manager in addition to save as or save copy as.
I have tried using revision manager, but keep getting the same result.
To clarify what I am trying to do, see attached.
In the attached diagram, Origional (A) Assembly has been copied and named (B) Assembly.
(B) assembly contains copies of both sub assemblies, and copies of their individual part files.
I have a cutout in Part 1(A) which includes geometry from Piece Part(A) to generated the cutout. See cyan arrow
When I go into the Copied Piece Part (B), I want to change it's geometry, to create a revised part.
However, I do not want the origional assembly to change.
As it stands now, Copied Part 1(B) 's cutout is still using included geometry from Piece Part (A) as indicated by the red arrow.
How can I get Copied Part 1(B) to use the geometry in copied Piece Part(B) instead? (blue arrow)
This way, the copied part files 2-6(B) will be associative to Copied Part1(B), and it's geometry,
which is generated from Copied Piece Part (B).
Basically I want to create a "standard" assembly, and then create vatiations of it by simply changing the piece part that drives all the other part files.
I tried family of assemblies a little also, but had problems with associativity between files not being maintained.
I had trouble opening your diagram, it's a rather large file and engineering.com seems slow to download, at least for me. Could I suggest you use a format other than bitmap, maybe jpeg or tiff.
Interpart links from the assy level can be problematic, we normally only use them during deveolopment and then drop them once the design is finalized.
I noticed that when I copy part files first, and then assy files, SE gives an error message noting that there are duplicate files in the new location. It indicates that if I click OK, the copies assembly will use the "new" part files. I have clicked ook, and the end result is what I have in the diagram. Upon expanding the new assm in rev manager, all of the component part and subassm files are the "new" copies. I have gone back into the origional piece part file, and made changes to it's geometry, and then checked the new assembly. Includes in the new assembly still show the old piece part's geometry, but it does not update the the revised old part.
It seems as though the include is locked in, and cannot be updated or broken.
Part2 has a cutout generated by including geometry from Part1.
Both Parts are put into an assembly Assy1.
Change the profile in Part1 and the cutout in Part2 updates.
We now want to create a new assembly, with new parts so open Assy1 in Rev manager.
Set action to COPY for the assembly and both parts.
Give them new names (in my case Assy1a, Part1a, Part2a) and perform actions.
Open and check the new assembly and parts and they are all linked correctly.
You say "SE gives an error message noting that there are duplicate files in the new location".
This occurs when you save an assembly to a new folder and that folder has files with the same name as files in the original folder. When you open an assembly, the first place SE looks for it's components is in the folder containing the assembly. So it is telling you "OK you copied the assembly to a new folder and I can now get some of the PARTS I need from the new folder, so I'll use them instead of the ones in the old folder".
This may be one of your problems.
In the old and new assembly check the links using Tools>Interpart Manager.
bc.
Quadro FX4600.
I would suggest doing your copies again using Rev Man and saving them to a clean folder.
bc.
Quadro FX4600.
Av8rrr try this primer
http:/
