Is there a problem with "Baesline" in Tc v9.1.2
We (engineering) have been trying to get IT to configure baseline.  I have been told by IT that v9.1.2 has a bug that will not allow the baseline release procedures to be defined in the env file.  Does anyone know if this is accurate?  I have searched GTAC and found no reference to this.
RE: Is there a problem with "Baesline" in Tc v9.1.2
The last time I worked on TC 9.1.2 was quite a while back, but if my memory serves me right the Baseline functionality worked in all the implementations I was involved in. I also can't recall any bugs with this functionality.
If the name for you release procedure has a space in it, it will need quotation marks around the name in the .iman_env file, otherwise there is not much else that can go wrong.
Thanks for the answer.  I took a look at the .env file and noticed there was no carriage return after the line defining the release procedures.  Had the IT guy fix it and it works perfect.....
