calculating areas from co-ordinates
i recently had an exercise where i had to calculate the cross sectional area at a road cross section. The information i had was in the form of levels and widths.
i had the following data,
eg: (x,y format)
(0, 103.21)
(0, 103.25)
(3, 103.32)
(6, 102.22)
(6, 102.27)
So basically its a trapezoidal shape taht i need to calculate area for. i solved this problem by creating a lisp in autocad, which could generate points which were in a text file. then i joined up and used area command. this was tedious and im sure there muist have been a way to do in excel.
RE: calculating areas from co-ordinates
Use yakpol's famous spreadsheet for defining an area by co-ordinates. http://yakpol.net/SectProp.html
corus
Check out a surveying book. There are a couple of different methods of calculating land areas from a closed traverse. The same methods may be used for cross sections.
