Reducing fuel cost in the boiler
How does the magnet installed in the fuel feed line reduces the Boiler fuel cost?
RE: Reducing fuel cost in the boiler
Maybe screws up the flowmeter
Or maybe the magnet is so strong it draws away the "cold"
Someone is messing with you
Can you send us more specific detail of your "magnet approach" to fuel savings ? Is one already installed at your plant ?
Are there pictures that exist of this installation or perhaps a website we could visit ?
What country are you located in ?????
-MJC
Ash9144 is right on! You have either been, or are about to be, scammed!
Orenda
I am going to go post a link to this thread in the automotive fora. Those guys deal with this all the time. They should get a real kick out of this.
rmw
Here is the link http://www.tinet.cat/~sje/mag_fuel.htm
Just a couple of quick thoughts.
JMW
www.ViscoAnalyser.com
Along with heat conservation and combustion efficiency measures suggested by ash9144, also look at steam waste surveys (leaks, malfunctioning traps, more return / re-use of condensate). Look up reports of steam trap management projects that have saved hundreds of thousands dollars in a typical plant of a thousand steam traps.
