120 Volt to 380 Vac Transmition
Dear All,
I would like to get description how to transmit DC power through AC Transmission line
thanks
Best regard
nusaduapower
thanks
Best regard
nusaduapower
RE: 120 Volt to 380 Vac Transmition
The term 'transmission' is usually reserved for very high voltages, typically 275kV or 400kV in the UK and whatever the equivalent is locally. 120V and 380V are distribution voltages.
You need to explain what you are trying to do more clearly. Your post contains far too little information for anyone to help you.
