Printing textures in drawings
Anyone know why this happens?
Here's a screenshot of my drawing, which is an assembly with some textures applied. The drawing view is shaded with edges.
http: //img232.i mageshack. us/my.php? image=text ureic5.jpg
When I print, view the print, print to .pdf, or save as .pdf, the view looks like this.
http://img 380.images hack.us/my .php?image =whitetext ureyz2.jpg
The texture is then white.
Any thoughts?
Thanks in advance
http:
http://img
Any thoughts?
Thanks in advance
John Graham CSWP
Mechanical Design Engineer
RE: Printing textures in drawings
I tried a lot of different things and scoured the options menus. The only thing that worked was to save it as an eDrawings file, then print from eDrawings, clicking the Print>Print Options>Print Shaded checkbox.
I had the same problem and it turns to be the printing settings.
Probably you have it like i had it on automatic, please change it to color and it will print it correctly.
When you hit print, go to properties and change the color detection to color instead of automatic.
Please let me know if you need more details
p2000,
Thanks for the suggestion, but it did not work. And, this still happens when trying to save as a .pdf
John Graham CSWP
Is your printer driver up to date?
Can you swap printers?
Can you open and print the assy on another PC?
We have a VAR recommended video card and driver. Printer is up to date, but like I said this happens when saving to .pdf, not necessarily printing to .pdf. Also, it does happen on other machines in my department.
John Graham CSWP
Which version and SP of SW are you using?
Just to confirm, this happens with Print, Print Preview, Print to PDF and Save as PDF?
What happens when you 'Save As' to other formats?
(eDrawing, bmp, tiff, etc)
I still get the white texture no matter what format I use. I tried printing to .jpg and edrawings, and both don't show the correct image.
I think it's a problem with SolidWorks not rendering the surfaces correctly. I've reported it to my VAR to investigate but have not heard back.
Thanks for your input
John Graham CSWP
How are you creating/adding the textures?
Are they cosmetic thds?
I have tried both, with various option selected, and mine works with Save-As.
The PDF shows both textures or cosmetic thds.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
We applied a texture to a surface (at the assembly level). It used to print fine up until a last week. We haven't made any system changes between now and then
John Graham CSWP
I run into this problem quite often when creating PDF's and this solves it for me.
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://designsmarter.typepad.com/rob_rodriguez/
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
