Hybrid V/s Non Hybrid modelling
1. Which of this is more advantageous to follow?
2. If somebody started a model in hybrid, Is it a good idea to change in between and continue modelling?\
BMR
BMR
RE: Hybrid V/s Non Hybrid modelling
1. Hybrid Mode is better because of grouping and sub-grouping and forced Ordered Geometric Sets.
2. I've found it impossible to convert a Hybrid PartBody into a non-Hybrid one.
That said, I only recommend using Hybrid Design if 1)everyone in your company uses it, and 2) you're just starting to use CATIA, and 3) you're suppliers won't have a problem working with your hybrid models
Do guys follow anything different in this situation.
BMR
Derek
I agree with DBezaire. All my friends don't recommend to use hybrid design. Even in some customer enviroments, you don't have a possibility to use it, because it's switched off.
best regards
Michal77
I second DBezaire's comments. Hybrid Design is very restrictive in a design context. I prefer to create my own system of organization, rather than being forced into (forced) ordered sets. The creation order of certain things - like wireframe -(in my opinion) should not matter on most design jobs.
The amount of data generated by Hybrid design (which cannot be isolated or removed) can also be overwhelming...
Catia Design|Catia Design News|Catia V5 blog
You are lucky enough to work for a company that has this procedure spelled out, obviously. Not everyone does. In fact, many companies don't even know what "hybrid design" is. Therefore, there is no constraint on the designer to use or not use it.
I have over 65 companies on my active customer list, and I doubt that even 20% would know what I meant by "hybrid design", much less have a procedure in place to define its use. You may or may not believe this, but I deal with it every day.
FWIW - I have never had a customer request hybrid design.
