local heat treatment
We want to perform local heat tratment of nozzle dia 240mm thk 47mm on the shell dia 6000mm thk 40mm (mat. SA516-70). Because of large diameter we do not want to use circumferential band, only local heating. Have you any bad or good experience in local heat treatment.
RE: local heat treatment
