fixation between bearing wall and flat slab
Dir sir
i make a design for a building with flat slab , and in design consideration i use fixation between the wall and slab , the wall width is 300 mm , it was a reinforced concrete wall ,and theres other wall standing on that wall as bearing wall also , thers a reinforcemet from the wall gos in my slab ,dose any know how that consideration work
RE: fixation between bearing wall and flat slab
You need to model it as a frame including the stiffness of the walls above and below. The fixity from this will be much less than full fixity, usually in the 10 to 30% range.
