I need help with bent metal sheet from DXF to SW
Hi, I would like to make a SW 3D model of some dxf's
These files are bent profiles with instructions to be laser marked and then cut and bended
Here is one file: http://peu.net/temp/bendquestion.zip
Whats the shortest path to make a 3D model of it? I have 23 files to model :)
Thanks in advance
Thanks in advance
RE: I need help with bent metal sheet from DXF to SW
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
I never worked with bends in SW, can you walkme thru the process of bending a sketch?
Thanks!
I use SW2007, no need to upgrade yet :)
http://w
http://www.sheetmetalguy.com/solidworks/
http:/
http
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
http:/
is a great tutorial, I didn't found it when I googled for help. Thanks!!
Pablo
Thanks to you all!
Pablo
I think this is because the part has already bent parts that are over this line, even if I make the bent line sketch small enough to fit inside the tab I receive this error.
Also tried to do this bend before any other and failed too.
How should I do it?
Thanks!
Pablo
Mike Halloran
Pembroke Pines, FL, USA
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
