How to define a concrete T-section ?
I have a problem to define a concrete T-section(just two rectangular shape built together). I used the section model from the standard precast I section and modified the dimension to get the size what I want, but it seems to be that I have to put a number on "D6". It cann't be zero. Any one has a thought to define a concrete T section?
Thanks a lot.
RE: How to define a concrete T-section ?
choose the T-shape from steel section, and then pick concrete material instead of steel from drop down box when modifying the properties.
Thanks, Lisica!
Yes but in the concrete reinforcement you can only choose the beam design type. What if you want to use the section as a concrete column (P-M2-M3 Design)?
Hello
Why do you need T-section as concrete column?
I think sap2000 can't design concrete column defined as T-section. Check what types concrete design supports.
I agree with lisica...Thats exactly what i am saying in my previous post...You can only design these sections as beams...Not as columns...
Use SD module(Define/frame sections/Add new../Other/Section DEsigner)  to define arbitrary shape sections.
