reinforcement in drop panels
for a two way slab with drop panels...
At an interior column I have a drop panel for punching shear reasons. Do I/Should I provide reinforcement in the actual panel itself? If so, how much? Say the drop panel is 15" deep.
I saw a detail once that had something like 6-10' long #5 bars spanning each direction down in the panel. Not sure why.
This reinforcment would be in addition to the regular slab reinforcment, so it would not be required for flexural reasons.
Any thoughts?
Any thoughts?
RE: reinforcement in drop panels
For drop panels you need to add it in case there are flexural stresses to handle. For example, could there be positive moments at supports due to seismic loads?. In Panama it is common practice to add something like #4@12" (sort of U shaped) in the bottom of drop pannels regardless. If required only for shear, I would not add anything.
I recently had a two-way flat slab design where I was relying on frame action of the column strip to resist lateral loads, however I didn't put reinforcement in the bottom of the drop panel as PanamaStrEng has indicated, however, this is a good point raised and I will bring it up with the seniors in my office.
