Import PDM card dimensions to model
I am wondering if it is possible to create a card in PDMworks that allows you to fill in an ID, OD, and Thickness and then it will create a configuration to a already existing file and use the dimensions imported on the card????
RE: Import PDM card dimensions to model
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Speaking in general this might be accomplished via some combination of the PDMWorks and SolidWorks API. I would write a macro launched within SolidWorks that gives me a form (i.e. card) with input fields. Then once you plug in the values hit a command button that creates my model and (optionally) dumps it into PDMWorks.
If you do a lot of this type of thing then you also might consider DriveWorks.
Hope this is helps,
ChrisG
