steel flitch plate buckling
Everything I have found regarding steel flitch plate design suggests that the plate must be sandwiched between wood members to prevent buckling. I have a situation where the builder wants to bolt the plate to an existing beam and we don't have the width to add another wood member, thus the plate will be on the outside of the member, no sandwich.
Can't I take my max bending stress and apply it to a slender column equation using my spacing between my bolts for my effective column length and then determine if the plate will buckle? I am thinking there has to be a tight enough bolt spacing to where the plate won't buckle and I can avoid the sandwich idea. Any of you ever done this?
Thanks a ton,
Thanks a ton,
RE: steel flitch plate buckling
Carl Bauer
www.bauerconsultbotswana.com
