problem with contact and thermal expansion
I'm a new user of this forum and I write this message because I don't use correctly contact in my Ansys analyse.
Indeed, I want to study the effects of thermal expansion of a first part on a second part. Initially, there is a gap between the two parts. The problem is that I don't managed to adjust the stiffness and the penetration:
*If the stiffness is low enough, the analyse converge but the first part cross the second.
*If I increase the stiffness, the contact converge but the expansion is not stopped by the contact. The penetration is too important.
*If I continue to increase this parameter, the analyse no converge.
Is there anyone to help me to adjust the parameter to have correct results?
thanks
Jérôme
RE: problem with contact and thermal expansion
I ask a new question:
In fact, I want to know if the normal stiffness is proportional to the apply load? and is there any calculation to know approximately the value of this parameter ? (because in Ansys help, we don't know how this value is used in the resolution).
(I used contacts with thermal expansion; the loads (due to the expansion) are maybe too important)
thanks for your help
jérôme
