NFPA-110 Code?
NFPA-110 Code?
Does anyone have any problem to comply wih these sections from NFPA-110? Thanks!
5.6.7.5 Power for fans and pumps on remote radiators and heat exchangers shall be supplied from a tap at the EPS output terminals or ahead of the first load circuit overcurrent protective device.
7.2.2* Level 1 EPSS equipment shall not be installed in the same room with the normal service equipment, where the service equipment is rated over 150 volts to ground and equal to or greater than 1000 amperes.
anbm
anbm
RE: NFPA-110 Code?
RE: NFPA-110 Code?
RE: NFPA-110 Code?
