Cannot open IGS file
I cannot open IGS file with Autodesk Inventor Professional 11. In the past, it works. Please kindly advise.
Many thanks in advance,
Kae
RE: Cannot open IGS file
Have you filtered out entity types (surfaces, solids, wires)?
Can you create a simple cube, Save Copy As cube.igs and then open then open that file?
Do you see the translator loaded in Add-ins?
Can you attach the IGES file here?
