Laing DDC 12volt 3.1 Pump
I aquired this 12 volt pump for a prototype wearable body cooling device. And I cannot figure out how to run this off of 12 volts. I've dug for information on how to work this thing but I dunno what the 4-pin configuration on this is. Im guessing one of the pins controls speed (5+ volts)? Can anybody help me out?
Pump:http ://www.fla bbergast.c om.au/mcp3 55-inline- 12v-dc-pum p-laing-dd c-3-2.html
Female Plug:h ttp://www. crazypc.co m/images/c ables/8pin /ad202.jpg
Pump:http
Female Plug:h
RE: Laing DDC 12volt 3.1 Pump
If you are unclear why not ask the supplier - it's usually the best way to get the correct answer.
Bill
"Why not the best?"
Jimmy Carter
