Preview Bitmap
Preview Bitmap
Has somebody tryed to download Sample Code to retrieve the SolidWorks preview bitmap and the display lists (as used in the SolidWorks Viewer) from solidworks.com . It demands imlode.h and implode.lib to build the sample. Can you advise me where can iget these files.Or may be another familar sample . Thank you.
RE: Preview Bitmap
I've used his snippet. It works as advertised.
RE: Preview Bitmap
RE: Preview Bitmap
http://www.cpuandsimplepdm.com/PublicSWAPICode.htm
I hope that helps,
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://home.insightbb.com/~scott.baugh/
