10uF 50V Low ESR caps
I'm designing a cicuit board and I need a 10uF 50V low ESR caps (10mOhm) and probably X7R type. I've been surfing and can't find one. Could someone help me to find this? Thanks.
RE: 10uF 50V Low ESR caps
Dan - Owner
http://www.Hi-TecDesigns.com
Q.E.D. Low ESR by definition.
Keith Cress
Keith Cress
Dan - Owner
So he won't even have a number.
The general result is, you better find an aluminum electrolytic cap that touts low ESR, or a Tantalum with low ESR, or any ceramic.
Under about 10W, most switching controller IC data sheets are suggesting ceramic caps, (like Henneshoe suggested), stacked on until you reach your capacitance requirement.
Keith Cress
Dan - Owner
Also garnered from having to do several switchers in the past year.
and smelling paint fumes..
Keith Cress
http://
EOF1973, I hope my suggestion still works for your situation, if not, happy hunting.
http://www.paktron.com/
Dan - Owner
