Save as with history.... ?
We are trying to figure out if it is possible to save a file (model and drawing) to a new name and save the file history from the previous name. Is this something we would be able to do? This is a PDM Vault thing. Thanks!
Bernie
SolidWorks 2008 SP3.0
Windows XP Pro SP2, Pentium4 3.00GHz
2GB RAM, Nvidia Quadro FX 3450/4000 SDI
RE: Save as with history.... ?
File history? You mean with revisions?
cheers
Yes with Revision history.
Bernie
Huh? We are using PDMworks. We tried a save as and the history went away and started fresh. we are trying to figure out a way to save the history from the previous part # to the new part #.
Bernie
Oh, sorry I misread. I don't think you can save/copy the history from one part to the other. It is a new part and will start from the first rev, unless your admin can setup a special check-in folder where you can start from any rev.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
I don't use PDMWorks but surely it must allow a backup copy of the assy and its parts to be made (with history). If so can you not just rename the backup copy and then move it back into the main vault?
cheers
As soon as I rename a file that comes out of the Vault it erases the history. I need to find a way to save the history but rename the file to a new number. (This is for R&D mainly).
Bernie
I need to figure out how to save the history while renaming. That is our issue. We need to know if we can keep the history so we can possibly rollback the files to the previous rev if possible.
Bernie
From a documentation control perspective, what you are asking to do seems incorrect.  When you do a saveas, you are basically saying, I want a NEW part that is similar to this other part.  A new part by definition doesn't have any history.  It sounds to me that you may want to look into creating some sort of "superceded by" or "previous document" entry into pdmworks.  I do not use pdmworks so I can't give you further info.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
At least in PDMWorks Workgroup, you can rename a file directly inside of the vault.  For this to complete successfully, you will need ownership of the file and any files that reference that file (drawings / assemblies).  You may have to change a setting using the VaultAdmin to allow renaming.
Eric
The only way I've seen this type of thing done is via Agile PLM.  You would create a new part using SaveAs, but the new part has something like a SavedFrom field that linked back to the original part.  You could do this in PDMWorks via a SavedFrom custom property that specifies the old part number and revision.  It would have to be manually filled out, but I can't think of a better way at the moment.
