Head loss through a hole
I need to know head loss through a circular hole on a 1/2" steel plate. Across the plate water is flowing through the hole. Flow rate is 1000 gpm and hole diameter is 5". My calculation is like this.
H=1.5 x V^2/(2xg) = 6.2 ft. Am I right?
Any suggestion would be helpful.
RE: Head loss through a hole
http://www.freecalc.com/fluid.htm
Best regards.
You introduced a useful site to me.
Thank you.
By the way, the result was the same as my first calculation.
