Rockwell software
Rockwell software
Hello Jones29847. I've got A quick question.I have worked myself into the controls dept. The Engineers have set me up with access to the controls software, and have turned me loose to learn on my own the software logic 5000 and slc 500, with limited guidance. Any heads up you can give me to make this A timely and positive learning experience would be appreciated.
RE: Rockwell software
drawings and programming
can you view these programs?
see if they have standard code, view it learn it. how do they implement standard code?
how can you write reliable code? how can you write code in less time than was done before? How can you write code that is at the quoted rate?
see if they have a plc and rack that you can use. see if you can upload and download, go online with the processor. If not get ahold of the area rep and see if you can borrow a rack and plc or go to their office and do this.
see if they have any written documentation on how they implement projects, if not make one up. See if it matches their expectations on project implemenation.
get familar with all the vendors and what they provide to your office. Collect all their cards for reference.
I have worked at a lot of controls houses, these are some but not all of what is expected of you, get up to speed, make yourself valuable. Then they will think your a good worker and a valuable controls person to have around.
Check out this link for some basics on RSLogix 5000.
h
Another good free reference is Hugh Jack's PLC books that you can download at http://www.mrplc.com/
I hope those help get you started in the right direction.
http://www.thelearningpit.com/lp/logixpro.html
Complete simulation software that mimics the RSLogix 500 software and plc. No machinery to crash, no downtime, no feelings hurt. There are complete process/machinery simulations. A great learning tool for the beginner. I give a copy to all our new techs. Buy the CD key version, it can be used on any pc.
Steve
