Negative skin friction on end bearing piles.
In the case of an end bearing pile founded on 'bedrock', placed thru a compressible layer called 'clay' with a fill material placed over the clay, just prior to driving, and the clays resultant consolidation causing down drag-negative skin friction = additional load on the pile. Is this additional load a permanent load or does it dissipate with time? Assuming the pile tip and the rock can carry the load.
RE: Negative skin friction on end bearing piles.
Note that much has been written on dragdown on the recent years (notably Fellenius) but these are piles in soil on soil.
The location of the neutral plane is a function of the load distribution in the pile which only includes the dead load.
You can download many of Fellinius's papers:
http:
Assuming the load can be adresses by the pile, is this a permanent, sustained, long term load on the pile? Or does it dissapate with time?
So for dead load, and maybe a portion of live load, yes the drag load is permenant. Note that drag loads occur in all soils and not only soft or compressible soils.
As Big H noted the piles must be structurally designed to carry the drag loads, or coated to reduce drag loads.
