Section View Gone Bad
I have a drawing that I'm creating multiple partial sections in. Sections created with vertical lines work fine but sections created with a horizontal line only work in one direction. The "bad" sections, which are supposed to be partial sections, show up as full sections, brown and with no depth control. If I flip direction they behave as expected.
I've tried starting a new drawing, starting off as a full section then changing to a partial section, moving views to different sheets, adjusting sketch locations and crying. All to no avail.
Any thoughts?
Any thoughts?
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
RE: Section View Gone Bad
Is this only happening for one specific section? Check to see how you've modeled the part. Maybe there's a simpler way, etc. Could be creating some kind of zero thickness geometry mumbo jumbo or something.
I've had sections act really wierd before, and remaking drawings/views wouldn't fix. Usually I just dealt with it and moved on, and chalked it up as a "limitation". Although those limitations only bug the living you know what out of me.
James Spisich
Design Engineer, CSWP
After closing SolidWorks for the millionth time today, to capture an Rx of the problem, the issue resolved itself, or at least disappeared.
Damn gremlins....
James Spisich
