Looking for guidance
I have almost zero experience in weld design and I am looking for some guidance. Let me describe my problem. I have a pipe and I need to slip on an annular plate and weld it to the pipe with a fillet weld. The plate is then loaded with a load w that acts concentrically all the way around the plate at a given distance from the pipe. See the attached drawing, sorry for the poor quality. I can determine the moment, shear and deflection of the annular plate for it being "fixed" at the inner ring and "free" at the outer ring. I want to determine if the weld will fail or be ok for a given loading. I am not looking for a step by step answer, just some guidance on how to analyze this particular weld. I have the AWS code and AISC steel manual but with out much experience I'm not sure how to apply it. Any help would be greatly appreciated. Thanks
RE: Looking for guidance
so....what you are doing is place a jacket around the pipe...correct?
Sounds like you know everything to calculate the stress in the throat of the weld.  Compare the result with the strength of the filler material.
Ted
I don't know if it is considered a jacket. Say the distance from the inner to outer ring is 4 inches and the thickness is 1 inch. If that constitutes a jacket, then yes I am putting a jacket on the pipe. I want to know that the weld can withstand the moment and shear transferred from the jacket.
If you are going to be doing more weldment I would look at getting a good set of books.  Take a look up any book by Blodgett his "Desgn of Weldment" is a great book that cover things like that it is well worth the $15 to $20.
It is the first book I look in to when doing weldments.
Chris
"In this house, we obey the laws of thermodynamics." Homer Simpson
Just ordered Design of Weldment and Design of Welded structures this morning. The Lincoln Series of Books are the best value I have seen.
