Drawing Tree Standards
Is anyone aware of any standards for creating drawing trees? Currently the drawing tree structure is dictated by our project managers and they all end up being different. I'd like to be able to standardize them somehow.
Bob
Bob
RE: Drawing Tree Standards
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
KENAT, probably the least qualified checker you'll ever meet...
There is a down loadable PDF, but it doesn't say much.
See section 4.4:
h
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Is there any reason why your drawing tree data would be defined by anything other than the parts lists?
I have seen similar problems with assembly trees, but these are due to parts lists being nonexistant, or inaccurate. There is also the issue what items are important enough to be on the assembly tree.
JHG
Have you found your answers?
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
Thanks everyone.
Bob
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
4.4. Drawing Tree
A drawing tree is used to control the development of drawings and their place in
the overall scheme of the project. Although this type drawing is not a
requirement for each project, when used properly and kept up to date, it can be a
valuable management aid and can be contained in a configuration management
database. See Figure 19.
However, that is a NASA doc not ASME so I can see why bashcraft is hesitant to take it as gospel.
If you have the Genium or similar manual they might have examples too, still not an ASME spec though.
thanks.
You can use the NASA info as a basis and modify it to suit your needs.
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
When the people fear their government, there is tyranny; when the government fears the people, there is liberty. - Thomas Jefferson
