capturing pictures problem
to capture images I use these commands:
/UI,COPY,SAVE,PNG,GRAPH,COLOR,REVERSE,PORTRAIT,YES
/RENAME,MSU000,PNG,,'%U3%_UZ_0_%T0%_%T1%...
image itself looks good, but the text is unreadable. Problem is with this PNG format. In ansys manual is not documented for use - I only try and it worked. The same problem is with BMP format. No problem is with EMF file - it is very good quality, but I would like to use PNG because its the smalest size (PNG - 60kB, EMF - 300kB, BMP - 1.2MB).
I want perform a nonlinear parametric study with many variables and capture images in each increment of load - I expect up to 50.000 figures so its size is important to me.
I use Ansys 11.0 64-bit.
Any help is appreciated, Thank you.
Lubo
RE: capturing pictures problem
hello Lubo,
try this
/GFILE, 800
/SHOW, PNG, PNG, 0, 8
/REPLOT
/SHOW, close
Plamen
hello Plamen !
You smiled when you wrote this. You knew that it will work. Yes it works, thank you a lot !
Lubo
interesting thing is that if I change value from 800 to 600 the text is sharper...
Hello Lubo,
you are welcome, I am glad I could help
For this change you are right it is interesting, I will check it!
Plamen
