plotting to file (tiffs)
This is killing me... Need to distribute drawings for viewing and not editing. Loaded 'Raster file export ADI 4.3' to create tiff files (using R14). The default settings for the printer config create a tiff with a black background/ white lines. The tiff is otherwise fine with everything visible. However when I manually change that setting to create the disired white background with black lines, the contents of the paperspace viewports dissapear. Doesn't matter what color the objects are. If I go to tile space and create a tiff with all the same print settings, those same layers/objects will now show up. What's going on? Should I abondon this approach and try something else?
RE: plotting to file (tiffs)
Have you tried exporting the drawing rather than plotting the drawing. I haven't tried this so I'm not sure if it works.
sc
I've not used 'ottopdf' so I can't give you direct help with that I'm afraid. The program I use is called 'ViewCompanion' (http://www.softwarecompanions.com/) and I've been using it for about a year now with no problems. You mention some trouble with the conversion when using ottopdf, do you have to specify stuff in ottopdf in order for it to convert? ...is that right?
Like I said I'm not sure about ottopdf but to use VC is simple, all you do is print as you would do normally. Choose your printer, pen settings, paper size and then pick the area you want to print (typically 'Extents' or 'Pick Window') and then set the scale. The only thing different you do is rather than printing direct to the printer to tick the 'Print to file' option and specify a filename/path. This .plt file can then be dragged into VC where you can view the .plt file before doing a 'Save As' as a .pdf file.
I hope that helps
Hindo
View Companion works on hp/gl format files, you may need to select a different printer before making plot files.
Regarding ottopdf, the plot limits are taken from the settings of LIMITS in AutoCAD. So if you want a 11 x 17 drawing at a particular scale, figure out what the plot limits would be in the drawing, set LIMITS then save before running ottopdf. (I've encountered some errors in plot window even after doing this though...)
Good luck,
Carl
thanks,
Bruce
With acad & raster images, the color of your background screen actually matters. If you want the image to be saved as a white background and black lines, use config to change
the color of your background to white.
I've taken the advice above and am just using PDF's created from PLT's.
thanks.
