I cant see the Deformed shape
The analysis results seems correct but when i wanna see the deformed shape or animation it gives an errer : "results for the current deformed variable are not available for one or more nodes contained in the model"
can sb help?
can sb help?
RE: I cant see the Deformed shape
i think the problem is related to the fact that you have to specifically request to print the current variable u are looking for in the odb file.
Barney
Thanks for respond
I have the same history request for another model and I can see the deformed shape there. How can i ask for a deformed shape animation output? Normally you have the deformed shape animation as a default isn't it true?
corus
