problem with ethylene glycol injection for hydrate inhibition
We have a natural gas refrigeration plant that should operate at -20F so we inject 80% ethylene glycol for hydrate inhibition. When the EG is present the plant will warm to about 5F and the EG seems to dam up in the system. If we inject MeOH instead of EG the plant will operate at -20F. Once the EG is reintroduced the plant warms again even if we continue the MeOH injection.
Is there a corrosion inhibitor, well treating chemical, etc. that could be entering the plant and reacting with the EG to coat the chiller tubes and inhibit heat exchange?
RE: problem with ethylene glycol injection for hydrate inhibition
