Profile tolerance on a gear web
I am dimensioning a gear web. The web is at an angle which I want to define as basic. I want to specify the large corner radius as basic, and an intersection point between the corner radius and the straight section as basic. Is this correct?
RE: Profile tolerance on a gear web
-handleman, CSWP (The new, easy test)
