Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I posted a query a short while ago and had an informed answer within a couple of hours. Terrific!..."
Geography
jp99 (Mechanical)
10 Sep 08 8:38
I have a question about applying ASD 9th Chapter H, combined axial and bending.
There is a factor accounting for the end moments, Cm, and the code states that Cm should be .85 for members restrained against rotation. I have a tubular member full penetration welded to a larger chord, so that seems correct.
But the code also states that Cm can be calculated from:
.6-.4M1/M2
When I calculate this factor using my end moments, which place the member in reverse curvature, I am obtaining Cm values much smaller than .85, around .2 to .5 depending on the values of the end moments. This doesn't seem right.
Does anyone have any insight into this calculation?
JAE (Structural)
10 Sep 08 13:14
Do you have transverse loading between supports?
If you do, then Cm = 0.85.
If you do not have transverse loading, you use the formula.
Close Box
Join Eng-Tips® Today!
Join Us             Close
