Help with sliding mechanism
I have a mechanism that I don't quite know how to classify.  Basically, it's a dowel pin that actuates sliding motion by riding into (forcing against) a slot in a plate.  The sliding pieces move parallel to the handle of the mechanism.  The handle contains the dowel pin which actuate the sliding pieces.  So, I have a pin with radial  motion, and plates with straight (resultant) translation.
The slot that the pin slides in is also a "V" shape.  What I want to know is, how do I optimize the angle of the slot to prevent binding during actuation?
I wish that I could provide pictures, but the firewall has blacklisted photosharing sites.
Thanks in advance.
Catia Design|Catia Design News|Catia V5 blog
RE: Help with sliding mechanism
Can you attach the pictures using the "...or upload your file to ENGINEERING.com" link below?
-handleman, CSWP (The new, easy test)
Sounds like a scotch yoke.
Don
Kansas City
Yes, I would say that it is a modified scotch yoke.  Rather than the straight slot, it is a "V" shaped slot.
We currently have a prototype built, but the slot angle is too aggressive, and creates a binding condition.  How do we calculate the correct angle?  We designed around travel of around 1/4" - 5/16".  The mechanism works when it is impacted, but we are looking for smooth operation.
Thank you.
Do you have room to use a cam follower instead of just a dowel pin?  This might reduce your friction enough to keep your present angle.
Don
Kansas City
You might consider calculating with your loads and use the material's coefficient of friction.  When the angle creates a condition where the friction force is nearly your applied force, the surfaces will not slide.  Or will begin to 'bind'.
Ted
Offset the central axis of the radial dowel pin from the center of the parallel motion by some amount in the x-direction. This prevents having no y-component of force in the top and bottom dead centers. That should prevent the binding.
V
If it is a scotch yoke, the "V" groove would tend to cause some backlash--wouldn't it?
