Equipment under kitchen hood
Can anyone tell me which code and section requires all equipment under kitchen hood shall be protected by shunt trip breakers and those breakers shall be tripped via a signal from fire suppression system in case of fire? Thanks!
anbm
anbm
RE: Equipment under kitchen hood
what family of codes is this designed under?? and edition
also some design to nfpa requriements
than can give better answer
While it is not mentioned in the IFC, NFPA 17A does not require this for solid fueled burning operations such as barbeque pits or smokers (thank goodness).
Don Phillips
http://worthingtonengineering.com
