Anti-corrsion "hard chrome" alternative
Outdoor equipment with carbon steel rods
1.5 x 0.5 wall x 4 @ 8' 4 @ 16' 4 @ 26' long
supports 8' x 12' display platform.
Rods occassionally raise up & down thru UHMW guides.
Rod supported by welded collar at top of rod and passing thru steel support. Bottom of rod is threaded and has a rod eye pinned to the platform.
Looking for anti-corrosion alternative to "hard chrome" (i.e epoxy with sealer/hardener).
RE: Anti-corrsion "hard chrome" alternative
Stainless steel tubing or hollow rounds?
Thin stainless wrapped around the CS? (Lockseam or adhesive bond)
Oil well sucker rods? ( I don't know if they're available in the length you need, but I think there is a selection of materials)
How many will you need? How long do they need to survive?
Mike Halloran
Pembroke Pines, FL, USA
http://ww
Currently unit is a prototype. Life before maintenance - 5 years.
12 rods per unit - 4 @ 8', 4 @ 16', 4 @ 26' long.
