Problem showing flat patterns on drawings
I used to be able to unfold a part, then switch over to drawing and make a new view using the unfolded part. I would then have all my orthographic views of the part in its finished state, and also a flat pattern view.
Now, i switch from the model to the drawing after the unfold operation and all my views are unfolded.
It all used to work but then I called a VAR for an unrelated issue who remoted into my computer and changed a bunch of settings. I called him and left a message, I doubt he'll be calling me back today.
SW2008 Office Pro SP4.0
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
RE: Problem showing flat patterns on drawings
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
the flat pattern is also specified.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
These are all released drawings, they were done a while ago. Why would they start malfunctioning now?
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Flores
Take a look at the configs of the part and then the configs each view is referring to. Your Default config should be folded to represent the finished part, then you have either a specific flat config that you made or there is a derived configuration that is the flat view.
I used to make a specific flat config until I figured out that SWX automatically creates this derived DefaultSM-FLAT-PATTERN. Now all I have to do is create the formed sheet metal part. When I drag it into a drawing I get the standard views to place on a drawing plus a flat pattern view.
- - -Updraft
Either way, you don't need to unfold or flatten to have access to the Flattened view in a drawing.
If you create a new drawing and then browse for a part to insert, the flattened view will be available from the View Manager at the LH side of the screen.
If you have the part open and File > Make drawing from part, the flattened view will be available from the View Pallette in the Task Pane at the RH side of the screen.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Please clarify. Are you having problems creating a new drawing, or opening existing ones, or both? Your first post made no mention of a problem with existing drawings.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
If not the current version, were they converted to the latest version before opening?
Have the parts or drawings, or the folders containing them, been moved or renamed?
Are the parts referenced in the drawings still good? i.e. Can you open the parts and flatten them without problem?
no. same directory.
yes i can open parts and flatten them out.
the problem was that all the flattened views on the drawings were breaking as I opened them. At this point the work has been completed.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
