Using pumps to transmit energy
I am working with a friend of mine to create an underwater propulsion system. My concept is to use an open hydraulic system to allow human generated torque to be converted to water pressure then back into torque to spin a propeller. It my seem counter intuitive, but I actually allows me great flexibility in locating the propeller that I wouldn't otherwise have. Horsepower and RPM are minimal at <2 and 90 respectively.
My question is what type of pump and motor would you recommend to use? True water based hydraulics offer a level of precision, pressure, and torque (not to mention cost) I just don't need. Is there a type of off the shelf pump that could be run backward efficiently as a motor? Eventually I need to build a proof of concept so designing from scratch isn't possible at this point.
RE: Using pumps to transmit energy
Since I am not a pump expert I could be wrong, but aren't hydraulic systems extremely efficient (90+%)?
"I think it would be a good idea."
- Mahatma Gandhi (1869-1948),
when asked about Western civilization
htt
Ted
I have considered that same perpendicular pulley/vbelt setup as well as other flexible shaft solutions, but none offer the simple ability to reconfigure.
h
Ted
