6061-t651 as welded strength
Can someone supply a yield strength number for 6061-T651 in the as welded condition and a source?
RE: 6061-t651 as welded strength
Chris
"In this house, we obey the laws of thermodynamics." Homer Simpson
Source: ASM HANDBOOK Volume 2, page 102, Table 82
NB: the ASMH quotes AMS 4021, 4022 and 4023 as setting a minimum condition-O Fty as 12 ksi/83 MPa...a bit different from the 55 MPa quoted above. It may depend what spec you've procured to/what industry you work in.
Other graphs in the ASMH indicate an as-welded R.T. Fty of 22 ksi (either 4043 or 5356 filler) with a recovery to 29 ksi (4043) or 37 ksi (5356).
Most references recommend re-heat treating the welded material.
Is there any specifcs there about the "preferred" Post weld solution heat treat and age temperatures and times?
"1.052 Solution heat treat. All forms except extrusions 970 F to 990 F. Extrusions 975 to 995 F, water (100 F max) quench...
1.054 T6 Condition. Solution treat + age. Extrusions and forgings 350 F, 8 hours. All other forms 320 F, 18 hours."
Minor caveat: this was written in 1972...
In the related thread in this forum called "Advice on Heat Treating 6061-T651 IAW ASTM B918" TVP has said:
"MIL-H-6088 is now obsolete, but it has information on heat treating Al alloys:
http
That has a few more specifics.
