Sketch animate and values capture
I'm working with a sketch to evaluate a mechanism.  I am using the animate sketch functionality, but cannot figure out how I may capture the reference values, length, angles and such.  Anyone know how this may be accomplished?  I need to capture the values in a spreadsheet for graphing.
D
RE: Sketch animate and values capture
option 1 : you can do this with a script.
option 2 : With Kinematic you can have output results with sensors.
option 3 : You have to do it manually.
option 4 : if you don't know scripting, don't have KIN License and don't have time to do it manually, then you need to have someone do your job...
Eric N.
Thanks.  Any tips on scripting this?  I have not written any scripts, yet.
;oD
record a macro and have a look at the code...
Eric N.
