Oval sweep
Oval sweep
Has anyone come up with an easy way to create an oval shaped helical sweep? It would be like a formed aluminum tubing. I've used a 3D sketch before but is is labor intensive.
"Perfection - a result of many mistakes."
Blair H.
SW 2007 sp2.0, HP x6400, 2.0ghz dual core xeon, 2.0 GB ram, Nvidia Quadro FX 1500
RE: Oval sweep
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
RE: Oval sweep
Blair H.
RE: Oval sweep
I'm fairly certain SW2008 has better tools for this job.
RE: Oval sweep
RE: Oval sweep
You may also get some good ideas from the curve driven patterns on Mike J. Wilsons site.
Download them here: http://w
Best Regards,
Jon
Gemini CAD Solutions
http://www.geminicadworks.com
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2007/2008
RE: Oval sweep
Blair H.
RE: Oval sweep
-handleman, CSWP (The new, easy test)
RE: Oval sweep
If first you do succeed...try something harder.
Blair H.
SW 2008 sp2.0, HP x6400, 2.0ghz dual core xeon, 2.0 GB ram, Nvidia Quadro FX 1500
RE: Oval sweep
RE: Oval sweep
RE: Oval sweep
Best Regards,
Jon
RE: Oval sweep
Below is my attempt using CBL's method:
Best Regards,
Jon
RE: Oval sweep
Blair H.
RE: Oval sweep
How did you created 3D curve for the last sweep?
I did not get it.
Thank you.
RE: Oval sweep
