Tack Weld a Nut
Tack Weld a Nut
Tack Weld a Nut
How should you indicate (callout) a Tack Weld for a Nut on a Drawing with Symbol/Verbage? Thanks for any Help.
RE: Tack Weld a Nut
Put a note in the tail if it is a tack to be consumed/removed (such as pre-production setup, etc).  If it is not to be consumed/removed for final welding, call it out as an appropriately sized small fillet, and add a note if needed for clarity.
